Attempting setup of Domino 11 Adsync for the first time. Set it up exactly by the book. Getting error:
Filename 'names.nsf' has error '13171':Dirsync encountered LDAP error - 16: No such attribute. [ - 16: No such attribute] - 16: No such attribute
Have dirsync debug enabled but its not telling me much.
Hello Kevin,
Please refer the recent webinar document on "Domino Directory Sync(DirSync) and Troubleshooting" and if the required configuration are done.
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0081339
And also on "Configuring Directory Sync"
https://help.hcltechsw.com/domino/11.0.0/conf_adsync_config.html#task_sxj_bny_43b
Thank you
Regards
Shrikan J
Hi Kevin,
Additional you can check if the attributes mapping are right as per the error code "Dirsync encountered LDAP error - 16: No such attribute"... 16 means as below.
0x10
16
| LDAP_NO_SUCH_ATTRIBUTE: Indicates the attribute specified in the modify or compare operation does not exist in the entry. |
Link: https://support.hcl-software.com/csm?id=kb_article&sysparm_article=KB0032952
Thank you.
Regards
Shrikant J
Hi Shrikant,
Does the sync process stop/fail if it tries to sync a value in Directory sync config doc, Sync tab, "Fields to sync to Domino" that does not exist in AD/LDAP? I have this populated with default attributes. I would think that if one of the attributes did not exist the sync process should ignore the null value and continue processing.
Also, I have Domino NAB design set to Domino 11 pubnames.ntf.
Thanks and regards,
Kevin
Three points:
1. In my Domino server config doc, LDAP tab, all values are set to default.
2. In my Directory sync config doc, Sync tab, all fields are set to default including "Fields to sync to Domino". LDAP filter field is blank (which is default value).
3. In my Directory Assistance doc, values are set thusly:
LDAP Configuration
Hostname: LDAPserver
LDAP vendor: Other
Optional authentication credential for search:
Username:
Password:
Base DN for search: OU=PEOPLE,O=HA
Connection Configuration
Channel encryption: None
Port: 389
Advanced Options
Timeout: 60 seconds
Maximum number of entries returned: 100
Dereference alias on search: Never
Preferred mail format: Internet Mail Address
Enable name mapping = checked/enabled
Attribute to be used as Notes distinguished name: mail
Attribute is to be used for all lookups: Yes
Type of search filter to use: Standard LDAP
I fixed this. So first I'll say that I am testing Directory Sync on a Dev Domino server. I ran through all the settings again and I found that the servername was not in LocalDomainServers group. I added it, restarted Domino and the process began to work.
