Hi all!After upgrading to Domino 6.5.4 my Swing Integrator 3.12 enabled application started to act weirdly.
Users have Author rights, and creating documents and attaching files via File | Attach works perfectly, but attaching files with Swing Integrator now failes with the error message “SwConnectLib - SW_RecreateAttachment 31 - 4067: Error In Module”.
Swing Software Support tells me that this error message is due to lack of ACL rights. When I change users rights to Editor, Swing Integrator works perfectly! Switching back to Author the problem reappears.
My application has been in production for years, and Swing has worked flawlessly all the time. That’s why I start to suspect Domino 6.5.4.
Does any of you have any experience? Is there a new “feature” in Domino 6.5.4 regarding Author fields?
Thanks in advance!
Best regards
Jan-Erik Larsen
Subject: Domino 6.5.4 and Swing Integrator ver. 3 - problems with Author rights
I have found a solution or an explanation for this situation, I guess.The problem is triggered by the attribute “Use LZ1 compression for attachments”.
When I turn this attribute on and off, the error comes and goes away accordingly.
This was described by Smita Agarwal here: http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/cee7cb193472fb2085256e37003808d8?OpenDocument, and I got this hint from SWING Software today. Thanks to both of you!
Jan-Erik
I’m developing an application with Swing Integrator 3.15. I also had the same problem. When the user was an Author I had problems with attachments in Swing. When the user was Editor everything work just fine. My solution was to put the users all as Editors and control what they can or can not do.By the way i just made an test in my application with an user as Author and work just fine, but I had made an downgrade from 6.5 to 6.0 because notice some instabilaty in the 6.5.
I know this doesn’t solve your problem but gives you a few light for you find the solution to your problem. And if you find the solution please tell us something.
Best Regards
Antero Santos
anterosantos@armsi.com
Subject: RE: Domino 6.5.4 and Swing Integrator ver. 3 - problems with Author rights
Thanks for your answer! I also “solved” this by giving all users Editor rights.
I have informed Swing Software about this problem, so I hope they can reproduce the problem and hopefully explain what to do.
They have confirmed that they are working on this issue.
Best Regards,
Jan-Erik
