Hello, I have 3 domino domains and one server face to internet. That server lisent for mailes to 3 domains.In some cases , I have repeated usernames in diferent domains for example: rlev@domain1.com and rlev@domain2.com.
The messages for these users are not correctly delivered.
What can I do?
Thank you in advance.
Guillermo
Subject: Domain problem
Is the outward-facing server’s configurations document’s Address Lookup field set to “Fullname only”? If not, that should take care of it – but there may be undesired side effects (unlikely, but possible); research how this setting changes the behavior of address lookups into the ($Users) view.
Subject: Thank you Bruce
Are there some way to tell to domino hey! chek sufix and check aliases too please!?Thank you in advance
Guillermo
Subject: I don’t understand the question
Have you looked at the documentation for the Fullname Only setting of the Address Lookup field? The pop-up help for that field label explains it clearly.
