I have been trying to add z-index to a couple of UI elements and through that, I want to make sure that I am not able to select/click the UI elements that are behind the higher z-index element. I am giving a high z-index number to the element but yet the elements behind it are clickable. Tried every value, but nothing is working.
Hello Vishal,
Please review the suggestion in the following post to check if it helps:
https://support.hcltechsw.com/community?id=community_question&sys_id=e984dcd11b58e8142518542f0a4bcb2e&view_source=searchResult
Below is the link to the limitation for Volt MX:
https://opensource.hcltechsw.com/volt-mx-docs/docs/documentation/Iris/iris_widget_prog_guide/Content/Appendix.html
Hope this helps! Thank you!
Thanks @Melissa Chavez . Assigning an empty event to the higher z-index element worked for me as told in the question shared by you
