Subject: Details
Adding a Notes team calendar’s entries to your Notes calendar
Note To enable team calendar applications for this feature, see the Changes to apply to older Notes Teamroom applications section below these steps.
To add a Notes team calendar’s entries to your Notes calendar, you must first replace the design of your mail template. To do so, perform these steps:
Open your mail.
Choose File > Application > Replace Design.
With Template server set to Local, click Mail (R8.5), deselect Inherit future design changes, and click Replace.
Once the design is replaced, exit and restart Notes.
After you restart Notes. perform these steps to add the Notes team calendar’s entries:
Open your Notes calendar.
In the Views panel of the calendar navigator, click My Calendars.
Click Add a Calendar.
Click the Add field, and select Notes Teamroom Calendar.
For Notes Teamroom Calendar label, type the team calendar’s title.
For Notes Teamroom Calendar url, type the team calendar’s address.
Click OK. Notes adds the team calendar’s title to the My Calendars section of the calendar navigator.
To see the team calendar’s entries on your Notes calendar, click the check box next to the team calendar’s title under My Calendars. (Note that if there are many entries on the team calendar, it may take a little longer for your Notes calendar to display them.) You can toggle the display of the team calendar (and any other calendars you add) by selecting or deselecting the calendar’s check box.
For this feature to work with an older Notes Teamroom application, an administrator must first make changes to attributes on the $CalendarView in the teamroom’s application template.
Attribute
Setting
STARTDATE$
DURATION$
EVENTTYPE$
HEXSTRINGCOLOR$
RGBCOLOR$
ICON$
STARTTIMEZONE$
ENDTIMEZONE$
STARTTIME$
DASH$
ENDTIME$
SAMETIMEINFO$
ICON2$
AGGREGATEDSUBJECT$
AGGREGATEDSUBJECT2$
APPOINTMENTTYPE$
CHAIR$
CONFIDENTIAL$
STATUS$
