I know that domino biult in a function called _doClick called on submit or on change value in a listbox field but in my form this function return error “Object doesn’t support this property or method” at the line form.submit();
this is all the code created ( i think ) by domino, which is my mistake??
function _doClick(v, o, t, h)
var form = document._webCorso;
if (form.onsubmit)
var retVal = form.onsubmit();
if (typeof retVal == "boolean" && retVal == false)
return false;
var target = document._domino_target;
if (o.href != null)
if (o.target != null)
target = o.target;
else
if (t != null)
target = t;
form.target = target;
form.__Click.value = v;
if (h != null)
form.action += h;
form.submit();
return false;
