When viewing a group calendar in the Notes 8.5.1, there is an action button called “Display options…” that allows you to control the amount of information to display (e.g. display only from 8 am for 10 hours to show 8am to 6 pm). This works fine, however when viewing the group calendar through a browser there doesn’t seem to be a similar option (and the option set in Notes for that calendar doesn’t seem to have any effect). Am I missing something or is this a limitation?
Subject: Same results
I tested and get the same results. It appears to be a limitation when viewing a group calendar over the web.
