Does anyone know if it is possible to disable right-click “Lock document” and still have the locking functionallity enabled when you edit a document?
Michael
Michael
Subject: Disable right-click “Lock document”?
If the right-click menu or the Actions menu has ‘Lock document’ as an available option, the NSF has the ‘Allow document locking’ property enabled on the first tab of the database properties dialog.
If you have no replicas of the NSF, you may want to use soft locking (have the ‘Allow document locking’ property disabled). See technote 1174820 for more information on soft locking.
