Difference between two dates
I have a start date and an end date. I’m trying to setup a rule. If end date is less than 5 days old, a pop up box will appear asking if the is a emergency change. if yes is selected another field will be populated and date will be accepted if not user will be required to re-enter the end date. Hope this makes sense …
Code I’ve started so far
Sub Exiting(Source As Field)
Dim UIDoc As NotesUIDocument
Set UIDoc = ws.CurrentDocument
Set Doc = UIDoc.Document
If Doc.ImpDateField(0) = "" Or Doc.ImpChgDateRequired(0) = "" Then
	Msgbox "Please enter a date value in the Imp Change Date."
	Exit Sub
Set StartItem = Doc.GetFirstItem("ImpDateField")
Set StartDateTime = StartItem.DateTimeValue
Set FinishItem = Doc.GetFirstItem("ImpChgDateRequired")
Set FinishDateTime = FinishItem.DateTimeValue
TimeDiff = FinishDateTime.TimeDifference( StartDateTime )
Msgbox TimeDiff/86400
If TimeDiff/86400 <= 5 Then
Subject: Difference between two dates
Hi Stefan,
I’m not sure I follow exactly what you’re trying to do, but if you need to get a time difference then the following should work and be relatively easy.
Dim vntStartDate As Variant
Dim vntEndDate As Variant
Set Doc = ws.CurrentDocument.Document
vntStartDate = Doc.startDate(0)
vntEndDate = Doc.endDate(0)
If vntEndDate - vntStartDate <= 5 Then
	Messagebox "End date is less than 5 days after start date"
The key points to remember are:
  • The two fields must be ‘Date/Time’ fields
  • You can also use the function ‘Now’ instead of vntEndDate (eg. “If Now - vntStartDate <= 5 Then”)
This example uses Lotusscript date variants to hold the date/time. These represent dates as the number of days since some date in the past. They can be subtracted to give the number of days difference in dates (and fraction of a day if times are included in both dates).
hth
Richard
