Difference between @SetField and uidoc.fieldSetText
The situation (notes 7.0.2):The form OutOfOfficeProfile in the mailtemplate contains a button “OK” with following formula-code:
FIELD SaveOptions:=SaveOptions;
@SetField(“SaveOptions”;“1”);
@If(
@Command([FileSave]);
	@Command([FileCloseWindow]);
@Return("")
I would like to add some more functionality (lotusscript) which I have defined in a new function in de Global Declarations of the OOO-form.
In order to be sure that the functions are performed in the correct following order (set saveoptions > FileSave > New script > FileCloseWindow) I want to rewrite this OK-button completely in lotusscript.
My problem: a can’t get my “SaveOptions” to work properly. No matter how (ui or backend) I define the setting of the field “SaveOptions”, the OutOfOfficeControl.Querysave method (also in the Global Declarations of the OOO-form) does not “see” my SaveOptions-setting.
What is the functional difference between “@SetField(“SaveOptions”;“1”)” and
Source.fieldsettext(“SaveOptions”,“1”) or Source.document.SaveOptions=“1”
By the way: The problem seems to be lying in the Dialogbox.
When opened as a normal form (from designer > preview OOO-form) my scriptcode works as a charm …
Any clue greatly appreciated!!
Arthur
Subject: Difference between @SetField and uidoc.fieldSetText …
Hello Tuur ,
Did you checked you dont have any code related to Saveoptions in the post Save event?
the difference between the Source.fieldsettext(“Saveoptions”;“1”) and the Source.document.Saveoptions = “1” is in the prior one the field is set using the frontend class where the physical existance of the field is requeired.in the later one the frontend document is accessed as a backend document , in this case you dont need to have a physicall existance of the field.if field doesnt exists it will create one and assigns the value.
Source.fieldsettext(“”,“”) [Lotus Script] == @setfield(“”;“”)
hope this clears you query.
Regards ,
Ravi K Daparthi
ravi.daparthi@gmail.com
