Difference between $ and $$ fields
Subject: difference between $ and $$ fields
There is no actual rule about fields starting with $, but they tend to be system generated fields. The $$ fields tend to be either temporary or compiled fields. For example, in the properties for a Form shown below, the fields such as $Flags, $TITLE and $HTMLCode are system information about the form, but the $$ScriptName and $$Script_O are generated on the fly when the form is saved.
Unfortunately, there is no rule to say you can create a field starting with $ or $$, so you can’t really count on those meaning anything. It is not uncommon for third party products to use such naming to fistinguish their fields from those actually on the form.
Subject: $
