Design template - test vs. production environments and Volt vs. Nomad
We are designing an app that will also use Nomad for mobile clients. And we also want to have a test and production environment.
How can we control this? In normal Notes/Domino we would create a template and use that for a database in the test environment. Once tested and Ok then we would copy the template to the production environment, change the database in production to inherit from the template.
All good and well known mechanisms :-)
But what would be the best approach in a Volt/Nomad environment?
1. Add Nomad design to the database without having it overwritten by Volt when changing/extending the app in the Volt editor?
2. Test vs. production environment?
Thanks in advance!
/John
My guess is that you need to develop the Volt side first. Then afterwards you can use Domino Designer to add in the traditional domino element for Nomad. AFAIK Volt will not override the existing traditional domino element in an NSF since they create their own form, view, etc. Also I don't think there is a way to convert an NTF to a .volt template.
Doing a Test and Production server would most likely work the same, Problem is to determine whether you need to do refresh design on the Volt side or Designer side ? Maybe it is best to maintain two branch, Volt Only and Volt + Other Domino element. In theory you could set an NSF to inherit design from two NTF (one of them is created from .volt).
Tinus Riyanto - Prisma Global Solusi.
