Hi all,
I got a problem about Delegation from 8.0.2 to 6.5.6.
User A is using 8.0.2
User B is using 6.5.6
User A was delegated to User B and grant “Read, edit, create, delete any document, send mail, enable Out-of-Office” right. when user B open A’s mail and create a folder. it success to do,But User A can’t found the folder in her PC.
Please help
Thanks All
Subject: Private folder?
Check the ACL to see if User B has access to create Public folders. If not, then the folder User B created is private -for only that user to see/use.
Subject: Private Folder
How can i know it is private folder or not?
Thank you
Subject: folder color
in the older client a shared folder is yellow and a private folder is gray.
Subject: Folder
HI,i checked the folder color has some different to other, but i don’t know how to say and i can’t post screen capture in here.
Subject: Folder Name
is the folder name problem?
***Leave <—This is the folder name.
Subject: re: private folder
A picture of a lock will appear on the folder icon, in the Client:
A picture of a key will appear to the left of the folder name in Designer.
