@dblookup and a dialog list field using formula for choices
What I am trying to accomplish is a list composed of a text and the unique id for the document:(format: “title (document_id)”
Now, it looks like it could work, but I seem to be getting complete nonsense out of my dblookup with
[ReturnDocumentUniqueID]
Here’s the choice formula:
@DbLookup(“”:“NoCache”;“”:“<path_to_file>”;“<view_name>”;CustomerName;
“OfferTitle”) +" (“+ @DbLookup(”“:“NoCache”;”“:”<path_to_file>“;”<view_name>";CustomerName;
“OfferTitle”;[ReturnDocumentUniqueId] +“)”
What I get out is this:
test1 (32 numbers, causes a “Invalid unique ID”)
test2 (32 zeroes, or some repeating sequence)
test3 (either same as that of test 2 or shifted some to either direction)
Now, the actual problem arises when I try to do
Set doc = db.GetDocumentByUNID(a number within one of those parentheses)
I keep getting a “Invalid Unique ID” error with this.
Anyone have good ideas on how to solve this?
Subject: @dblookup and a dialog list field using formula for choices
I’ve tried your formula, but I choosed to write it in a different way. You might try this one.
L1 :=@DbLookup(“”:“NoCache”;“”;“ViewRefContact”;f_LastName;2) ;
L2 := @DbLookup(“”:“NoCache”;“”;“ViewRefContact”;f_LastName;2;[ReturnDocumentUniqueID]);
show := L1 + “(” + L2 + “)”;
@Prompt([OK];“Test”;show)
Subject: RE: @dblookup and a dialog list field using formula for choices
Thanks for this one, makes my code a bit more readable…
But it still doesn’t solve the problem.
Each returned entry still gives me a “Invalid Universal ID” error.
