DB2 Access - Problems Enabling
My Environment:Domino 7.0.2 on Windows
DB2 Version SQL08025 (8.2.5 or 8.1.12.99)
Everything seems to follow the instructions up to the point where I go into the Notes Admin client and select the DB2 Server and Tools - DB2 Server - Enable Server for DB2.
I then get the following error message:
IBM DB2 does not appear to be installed on the Domino Server. You need to install DB2 before you enable the server for DB2.
I have DB2 installed…
HELP
TIA
