Custom calendar based on iNotes --- how to open it using MY frameset --- ON THE WEB?
Hello folks,
I’m stuck on something so simple… I need to “develop” a community calendar (client and web). So I figured I’d create a new db, using the inotes template.
I obviously want it to open directly to the caledar. No problem in the client - used the db launch option to change the client setting to a new custom frameset. The db WEB launch option doesn’t work though. I tried chnaging it, and the db still opens with the default mail stuff.
Any ideas? I’m going crazy tracking this thing down.
Thanks for your time,
Rachel
Subject: Custom calendar based on iNotes — how to open it using MY frameset — ON THE WEB??
While open on the Web…
Preferences - Other - Default startup view.
