Connection to MS SQL ser
I have read the OLE DB in the designer help. It said a lot about how to indicate the variable in OLE DB connectivity. I tried by creating a “data connection” in the “Shared resource”. After declaring the entire fields, I was wondering how to display the data from the connection I made.
I’m lost now. Where should I start? I want to create a view and display the table from my SQL server in the view. Help pls… Thanks
