Hello,
is possible connect Sametime Limited Use with Verse and iNotes. Every information is for v 11.x but not for 12.0.1. Problem is probably X-Frame-Options' 'sameorigin' .
Anybody know if there is solution?
Leoš
Hello,
Leoš
Assuming CORS (x-frame-options) is the issue - then yes, it is entirely possible.
Docker or Kubernetes?
Check the information provided for Sametime 12.0.1 in below URL and see if it helps.
Sametime Chat Verse | iNotes integration not working due to X-Frame-Options in Sametime v12.01
Hi Leos,
Here is information to help with Sametime 12 that you're after:
Sametime Integration with iNotes+ Verse Sametime 12.x
Best,
KK
