I have a view with only the following line in the postopen event:@Command([ViewShowOnlyCategories])
When I open this view in the notes client everything works as expected, but when this view is used in a frameset I get the error
‘Cannot execute the specified command.’ and I see everything not only the categories.
Has anyone an idea how I can solve this error or if there is any other possible way to get a similar result?
Subject: @command problem in view used in a frameset
In the PostOpen of the view put the following code:
@Command( [ViewExpandAll] );
In the QueryClose of the view put the following code:
@SetTargetFrame( “NotesView” );
@Command([OpenView]; @ViewTitle);
Subject: RE: @command problem in view used in a frameset
Brilliant! Works great
