Coding Problem
I need help in programming as i’m quite new to this.
Scenerio
I have a document and user make amendment to it. I need to keep trace to the amendment done.
So i need to have a revision changes and need to keep the old document. I need to know how can I make a copy of the existing document in the same database??
I’m using Lotusscript!
thks!
Subject: Coding Problem
You can look at using “Versioning” … check the Form properties.
Subject: RE: Coding Problem
can this work in web?? thks
