When trying to use one of the Chart widgets Iris has to offer in a responsive web application, the logic responsible for transferring the chart data or chart title doesn't seem to be called or work correctly. Take the DonutChart for example. It will always use the placeholder values that are specified within the HTML file it is based on. Thus, no matter what data is specified in the Component tab, the chart will always display the same data.
This is not the case for native applications, so the controller code itself doesn't seem to be the problem.
Are these charts not supposed to be used in Web Apps?
Thank you for your input!
Cheers
P.S.: I'm using Volt MX Iris version 9 SP 2 FP 38
