Can't get sametime meetings web interface running
Hello
I've installed sametime meetings 11.5 preview as a docker image on a CentOS linux server.
I've configured the custom.env file following the documentation. The command docker ps shows me that it is up and running but when I launch the browser to open up the Sametime meetings login page I can't connect and firefox throws me an error "Secure Connection Failed" PR_END_OF_FILE_ERROR
I thought it was related to the fact that I've commented out DOCKER_HOST_ADDRESS in the custom.env file, so I adapted the file, deleted /jitsi-config directory and redid the installation but still the same issue.
Hello,
I understand you are trying to login Sametime Meetings using Firefox which is not a supported browser atleast for this pre-release build. Try using Chrome and see if you see the same behavior?
Also make sure DOCKER_HOST_ADDRESS is an reachable. the following is the response from HCL for my issue with DOCKER_HOST_ADDRESS. Hope it helps.
set/validate the DOCKER_HOST_ADDRESS
in custom.env - ensure it is to the rout-able/expected IP of the MeetingServer
steps -
a) update custom.env
b) docker-compose down
c) delete the 'jitsi-config' directory
d) docker-compose up -d
Best Regards,
Prashanth
Most likely the docker-container NGINX is unable to hit your proxy server.
Open a case so we can review logs and provide you with the solution.
