Cache problem with global variable
Hi all,
i have a strange behavior with a agent that calls a function in a script library.
Here is the scenario (hoping that some of you can reproduce this …)
I have 2 empty forms (Form ‘A’ anf form ‘B’)
I have 2 views (view ‘A’ for Form ‘A’ and view ‘B’ for form ‘B’)
 View 'A' has the 1st column sorted with value 'O' (hard coded)
I have 1 document created with form ‘A’
I have 1 simple action agent that changes the field ‘FORM’ to ‘A’
I have 1 script agent as goes :
Use “FunctionsLib”
Sub Initialize
dim s as new notessession
Dim db As NotesDatabase
Dim zzdoc As NotesDocument
Dim MyView As notesview
Dim collectionExpDB2 As NotesDocumentCollection
Dim NotesDateTimeStart As New NotesDateTime(Now)
Set db = s.CurrentDatabase
DO
Set MyView = db.getview(“A”)
Call MyView.Refresh
Set collectionExpDB2 = MyView.getalldocumentsbykey(“O”)
Set zzdoc = collectionExpDB2.getfirstdocument
While Not zzdoc Is Nothing
If zzdoc.form(0) = "B" Then    ' this should always be false !!
   delete zzdoc
end if
If zzdoc.Form(0) = “A” Then
    zzdoc.form = "B"
    zzdoc.Save True, False
    ExportData  zzdoc           ' This is in a script library
end if
Set zzdoc = collectionExpDB2.getNextdocument (zzdoc)
Wend
Sleep 30 ’ sleeps for 30 seconds
Dim diff
Dim NotesDateTimeNow As New NotesDateTime(Now)
diff = NotesDateTimenow.TimeDifference(NotesDateTimestart)
If diff > 600 Then 'the agent runs non-stop for 10 minutes
  Exit Sub
Loop
end sub
And i have 1 script library (‘FunctionsLib’) as goes
(Declarations)
Dim doc As NotesDocument
Sub ExportData (MyDoc As NotesDocument)
’ if declared locally, i don’t have the problem.
’ Dim doc As NotesDocument
Print "Start of  function"
Set doc = MyDoc
Print "End of function"
So, my problem is when the agents gets the collection from view ‘A’, it sees 1 document with the good value (‘A’) in the form field. The agents then changes this value to ‘B’. so the document dissapears from the view ‘A’ and goes in the view ‘B’. If you use the agent to toggle the document back to view ‘A’, it reappears in the view ‘A’ and the agent that is still running gets the doc with the collection. The problem is that my field value (in the agent) has ‘B’ as value ??? You have to toggle back the document within the same agent cycle (300 seconds)
If you have the same problem, try changing the :
dim doc as notesdocument place from (Declarations) to locally to the function and the problem dissappears !
I don’t know if this is clear but it is a simple test for you guys to try out and let me know if this is a big bug or not !!
