Button Hotspot - how to keep color on web?
I have a button hotspot used to submit a form. In the client - in designer - I can set the button to a blue background with gray wording and rounded corners, but when viewing on the web it is just the standard gray box. How can I keep my color on the web? Thanks much!
Subject: Button Hotspot - how to keep color on web?
I usually use an action hotsopt with the text only, then use a style sheet to make the button, like so…
  1. Create your action hotsopt and just use the text of the button label.
  2. In the hotspot properties on the html tab enter ‘hotspot’ (no quotes) as the class name.
  3. Use the following style, you can either enclose it in style tags on your page in the HTML header or use an external style sheet.
/* **** Hotspot buttons **** */
.hotspot {
background-color: #cde;
color: #000;
border: 1px solid #444;
border-bottom: 2px solid #000;
border-right: 2px solid #000;
padding: 1px 4px 1px 4px;
font-family: Arial, sans-serif;
font-size: 8pt;
height: 10px;
text-align: center;
text-decoration: none;
A.hotspot:link { color:black; background:#cde }
A.hotspot:visited { color:black; background:#cde }
A.hotspot:active { color:black; background:lightgrey }
A.hotspot:hover { color:white; background:#37f }
/********** end hotspot style *************/
Hope this helps
Subject: RE: Button Hotspot - how to keep color on web?
You can also go to the hotspot’s HTML property and control the STYLE.For example:
font-family:Helvetica;font-size:xx-Medium;color:white;background:black;cursor:hand.
Thank you both very much!
