Some user’s busytime is appearing 1 hour out (for their set lunch time, for example)…they have their schedule set in their calendar profile for 8am-12pm - 1pm-4pm. If you try to book a meeting with them and check their schedule, they appear to be unavailable from 1pm to 2pm, not 12pm to 1pm.
I found in busytime that the “TimeZone” field of their record displays funky results for them:
TimeZone —> “Z=5$DO=1$DL=4 1 1 10 -1 1$ZX=25$ZN=Eastern”
Mine is working ok and I know my PC is patched and Notes settings are ok (use OS timezone). My busytime record shows this value–> “Z=5$DO=1$DL=3 2 1 11 1 1$ZX=28$ZN=Eastern”
I wonder if the user’s PCs aren’t patched (they say they are), or they have their Notes prefs set to not use the OS timezone?
Any ideas folks?
Thanks!
Pat
Subject: Busytime problem - DST related??
The fact you’re seeing DL=4 1 1 means LN doesn’t see the patch applied.
I had a few people who DID apply the patch but never rebooted their PC. Therefore WIndows and LN did not see the changes.
Hello,
It’s certainly a DST issue. I would recommend checking the 2 things you listed starting with verifying the system time.
Subject: RE: Busytime problem - DST related??
Hi Pat,
Seems to be similar:
http://www-1.ibm.com/support/docview.wss?rs=899&uid=swg21256439
If you ask your users to create a calendar entry, what will be the value of the SatrtTimeZone\EndTImeZone fileds?
JYR
Both fields say: “Z=5$DO=1$DL=3 2 1 11 1 1$ZX=28$ZN=Eastern”
Do you think rebuilding busytime.nsf on all servers will fix this problem?
Thanks!
Hi Pat,
It would be a good idea to rebuild the busytime.
Just a quick test, can you issue a : Show config DstLaw on your server console?
Is it the right value?
JYR
yes …both are DST=1 (clustered mail servers)
