Body - fields will be duplicated in Lotusscript with CopyToDatabase
The Body field in Richtext-Mails will be in documents twice , if the Body will be greather than an certain amount of bytes there are normally two in our case four Body fields.
MS Windows Terminalserver 2012, Windows/Longhorn 6.2 Intel Pentium, Client Software Windows on Citrix , IBM Notes Basic 9.0.1 FP2
The domino servers are 9.0.1 but I believe it is a problem with the Citrix client, there are so much other users they do not have these probleme.
In our case we will copy a document via a transfer database in a crm suite database
'copy document to transfer database
Set transferDoc=sourceDoc.CopyToDatabase(transferDb)
Set authorsItem = transferDoc.ReplaceItemValue(“xRights”, “*”) 'to give user author access for the new doc
If Not authorsItem Is Nothing Then
authorsItem.IsAuthors=True
Call transferDoc.Save(True, True, True)
'copy document to target database
Set targetDoc = transferDoc.CopyToDatabase(targetDb)
I don’t know why this will be created, when we use script debugger there is no error visible.
The result are two times the content of a memo in the document in the target database.
Subject: Try a forall loop
Try creating a new document in the target document via db.CreateDocument and do a forall itm in sourcedoc.Items and copy each individually. I believe it will only pick up a single instance of the Body field.
