Blackberry read/unread issue
I recently upgraded to BES 4.0. This added the ability to sync read/unread marks between the Blackberry handheld and the user’s mailfile.
The problem is that when you read a message on the Blackberry, that message returns to unread status when the BES server reconciles the email. However, it will remain in an open status if the Notes mail client is running. It will also change the status of the message in the Notes client to read.
I have the security set as the BES documentation suggests.
The mail files are located on iSeries running Domino 6.0.1 and the BES is on 2000 Server running 6.0.2 CF1. I am not working with multiple replicas. The BES points directly to the mailfile in the person document which is on the mail server. The BES state databases are on the BES. RIM support says that this should be fine. They haven’t had anyone else experience this problem. I would just turn off the read/unread sync, but it’s automatically on if you use email reconciliation.
Thanks for any advice!
Subject: Blackberry read/unread issue
I called Research in Motion (Blackberry) again today to follow up on the case that I have with them on this issue. They said that another instance of this has now occurred. They suggested that I upgrade the mail server to Domino 6.0.4 or later. It’s related to the changes in the way read/unread messages maintained.
But since another group handles the iSeries, I’ll have to wait a few weeks to test this.
