Birthday Calculation Problem
hiI have a problem on showing the birthday of employee .
I have a view with first column birthday date and second column is employee name.
and in another form i have Computed text field in which I want to show the name of the employee whose birthday is on that day.
Subject: Birthday Calculation Problem
I thought you will check your last posting:
http://www-10.lotus.com/ldd/nd6forum.nsf/DateAllThreadedweb/04c91a9cd84ded81852572950051d4db?OpenDocument
Use the below formula in the computed value
temp:=@Today;
@DbLookup(“”;“”;viewname;temp;2);
and
  1. your view first column should be sorted.
  2. The date format for @today and your DOB in the form should have same format for example DD/MM/YYYY. Then only it returns the correct value.
Let me know if you have problem.
