We have an “older” app where I’d like to enhance the web UI. It is now using the outline and displays that in the web using the applet. Same for buttons.
I know I can do Ext.nd on the app but that will also give me some problem with UI. Takes a long time to get the old look&feel back.
I have been looking at Prototype to use ajax and script my way and perhaps add-on script.aculo.us as a nicer UI.
But the drawback is that I cannot use the “getviewentries” since that is blocked by policyreasons.
Any ideas on a good way to “replace and retire” the applet with a minimum of effort? Any nice frameworks to use?
No, XPages is still not an option since we will run these on R6.5x for a while longer.
