Hi
We’re planning deployment of DAMO 6.5.4 on XP with Outlook 2003 as the frontend.
We’re a hotdesking environment, and everyone uses Windows roaming profiles. Given that there have historically been some issues with Notes and roaming profiles, I’m wondering if anyone can steer me in the right direction for running DAMO in such an environment? I’m think issues such as file locations, need for registry hacks, changes to global policies about what is or isn’t included in the roaming profiles to best support DAMO with the least risk of data corruption (or massive profiles!).
All help appreciated.
Subject: Windows roaming profiles?
Hi Darrell,
Admittedly, I’m not familiar with Windows roaming profiles. Notes, however does have a roaming user capability where the roaming Notes user has his data stored on the Domino server and can be pulled down to any Notes client having this feature enabled.
With regard to Outlook/DAMO there are the first, most obvious answers for a user wanting access to his/her mail anywhere in the organization. Domino Web Access (DWA) where a browser provides best access and functionality when the user’s mail file is predicated ion the iNotes6.ntf.
Another option could be some remote software such as VNC where a roaming user can use a simple VNC client or a browser to connect to an Outlook/DAMO installation.
DAMO has the Multi-User option which allows for each user to have his/her own data directory. This data directory might be out on the network. Like Notes, however, there can be problems caused by the system files not being local.
When the Windows Administrator install DAMO, that installation becomes available to all users of the workstation. Now when the DAMO profile gets created either by the individual user or the administrator using the “RunAs” capability of Windows, that DAMO profile is available only to the individual user.
Hope this provided some useful options…
Thanks, Mike
Subject: RE: Windows roaming profiles?
We’re been playing a bit, and the following ALMOST works with DAMO 654: set up the MAPI profiles to save to separate folders on a share. This allows multiple roaming users to access their diaries and calendars, but there seems to be a problem somewhere waith the addin – for users other than the one under whose account DAMO was first installed (with the multiple user options checked), the ‘Domino Preferences’ pane is missing from the Tools->Options menu in Outlook 2003. Users can read and send mail, browse the Domino Directory, and schedule meetings, but not change their Domino settings.
Also, even if a user has enabled shared access to their calendard, those users for whom the Domino Prefernces are missing can’t actually access their calendar: they get the error:
'Unable to display the foler. Your profile is not configured to support this option for this user.
Any ideas?
Subject: A couple of issues …
First, you should consider joining the 6.5.5 prebeta discussion. DAMO 6.5.5 has many improvments over 6.5.4.
With regard to Domino Preferences not being available, this can typically happen if there is an Outlook crash, and when starting Outlook the next time, we choose to start Outlook in Safe mode. The result is that the DAMO add-in will not be loaded.
There may be another issue here that has to do with Windows security. That is, that the user who creates the profile may be the only user to have access to that profile and the associated data files depending on where, in the file system the user’s data directory is. However, the DAMO add-in should be available to all users as it is in the DAMO program directory and not a user’s data directory. I don’t want to complicate the issue but do want to make you aware that Outlook uses Windows permissions generally to allow access. In the Windows on-line help system, look at the “RunAs” capability.
To restore the DAMO add-in
Tools->Options->Other tab->Advanced Options button->COM Add-ins button
If the INotes Outlook2K Addin is displayed, remove it, restartart Outlook.
Then add it again via Tools->Options->Other tab->Advanced Options button->COM Add-ins button->Add
Navigate to the DAMO program directory and select inotesoutlookaddin.dll
Restart Outlook.
With regard to the error:
“Unable to display the folder. Your profile is not configured to support this operation for this user”
SPR #SBOR69PRZL is open to address this error when it is generated by clicking on the “Open Shared Calendar” link. This SPR is still open.
Tahnks, Mike
Subject: RE: A couple of issues …
Thanks. In our case its unlikely to be a Windows permission issue – all users have admin permissions on the machine, and there’s no report from the system about the addin having crashed outlook, and it hasn’t been autodisabled by outlook either – it just seems to not have registered itself with outlook except for the user under whose name its installed. Any thoughts? I’m happy to put some debugging time into this if it would help, as I’ve been waiting for a version of DAMO which is (relatively) bugfree on shared calendars and works with roaming since at least the end of next year (see earlier postings). Its a long slow process! How do I join the 6.5.5 prebeta?
Ok – the COM addin tip reliably restores the addin functionality – thanks for that. In all cases, all but the first setup user do NOT have the addin registered, but adding it in manually works.
Just FYI, the SPR #SBOR69PRZL issue is also 100% reproducible for us, on all users set up.
The environment is XPSP2, Domino client 6.5.4, DAMO 654 against Domino server 6.5.1 on win2k3. If you would like more info, just ask.
Regards
- Darrell (keen to get on the 6.5.5 trial).
Hi Darrell,
With regard to the COM add-in being loaded by only the first user, off hand, there is nothing that comes to mind. However, whenever we put the data directory out on the network, it is not unusual for odd behavior to result. The obvious test in this case might be to do everything the same and with the same users, keep the install local to the machine. Another thought is back at the permissions issue. Even if users are administrators, they do not have access to users’ Outlook profiles for example when those profiles were created when those other users signed on to Windows. Just a possible explanation. Just as profiles are protected in the Registry, the COM add-in is also.
SPR #MROE6DKGWV addresses the fact that “Open a Shared Calendar …” link is not working. This is an excerpt from TechNote #1202798
The Managed Calendar capabilities of DAMO can be leveraged to allow a shared Calendar or to access a Mail-In Database by multiple users. The technote “Request for Notes/Domino Group Calendar for Users to Share and View Free Time” (#1193770) discusses the shared calendar capabilities using Notes/Domino. This functionality can also be applied to Outlook/DAMO. Below is an excerpt from the technote:
“Currently, the only way to have a Group Calendar like this is to register a mock user, and give all members of the group access to this mail file. They can all view/access the Calendar, but their free time is not updated. This would be very useful for user looking to have a common Calendar.”
The same process would apply to a Mail-In Database
Registering for the DAMO 6.5.5 forum - I’ve let Jan Kenny kow you are interested. She’ll work her magic.
Thanks, Mike
also, sorry where can i find full details of SBOR69PRZL and track it?
thanks
