For some reason my RichText field with option
“Fit for OS” is not editable on the web.
When I try to edit the doc.I can see the tool bar but the actual field seems to be gone or not editable…
Any sugestions?
/L
Any sugestions?
/L
Subject: I am confused
I think “Fit for OS” is a translation, which is why I’m not familiar with it. In English, the closest setting I see to that is “Native OS style” which gets grayed out when you selest Rich Text as the field type. So, it’s not a valid option as far as I know.
Perhaps your problem is due to something else - does the field have any HTML attributes? are you using the DHTML setting or Java setting?
Hope this starts to help you search to figure it out,
Dave
Chub Toad, LLC
Subject: Best fit for OS Not editable???
Is your field within a table? Then it will not work.
