BES 4.1.6 and Domino 8.0.2 - I'm having problems
I’m brand new to BES, but had some help setting it up from a fellow admin (who uses it with GroupWise). It’s up and running and works quite well…for about 24 hours. After that, the BES agent process seems to disappear, and mail stops routing to the BBs. I’m not sure where to start looking to nail down the problem but I thought I’d ask if anyone else has run into this issue. The only resolution is to kill the Domino server (it will not shut down, I’ve waited 45 minutes) and start it again.
Subject: Version not compatible
We use version 8.0.1, of Domino, with BES 4.1.6. 8.0.2 is not supported.
Subject: *same here
Subject: Great alternative to BES
A very good alternative to BES is System Seven made my Seven Networks of California.
Their application natively supports Mail, Calendaring & Contacts for the following mail systems:
  • Lotus Notes / Domino
  • Exchange (and Outlook Web Access)
  • Yahoo
  • Hotmail
  • GMail
  • POP3, IMAP
  • etc…
Plus it works on all sorts of devices:
  • Windows Mobile 5 / 6
  • Smartphone / PocketPC
  • Symbian
  • J2ME
  • Brew
And best of all…you can currently get it for free at:
http://preview.seven.com
We run it on our Domino servers for all our users. Excellent product!
Subject: Not good in this either, but
tell bes about
load bess
(and I think tell bes quit)
Subject: BES and Domino
BES does have memory leak issues. Make sure you’re not running it on the main production server.
Also, check with Blackberry as to which version was the first to support Domino 8. I think you might need to do an upgrade.
