A new feature in notes allow you to see a background in the body of the e-mail. Instead of the plain white background, you get the background you usually get in the header selected by the user that sent you the e-mail. Unfortunately, sometimes you get stuck with the plain white background and there is no way to reactivate the background in the body. So my question is, is there a way to enable or disable this feature that may seem nice for many and disturbing for some.
Subject: Background in note body
If you open up the memo form in desinger, Form Properties, 4th tab, uncheck ‘Allow users to change these properties’.
