Awareness in iNotes using Sametime Proxy - not working
I am having LTPA issues after following the “Lotus iNotes Sametime Proxy package” article on developerworks.
I have a Sametime 8.5.1 Proxy server running on RHEL and a Domino 8.5.2 server on Windows 2003 SE which is the LDAP and iNotes server. One Community server is running Sametime 8.5.1 on Domino 8.5.
I followed the instructions in the article but have a problem of awareness not working in iNotes, also I now cannot log into the stwebclient.
Firstly, the location for the stproxy directory in /opt/IBM/WebSphere/AppServer/optionalLibraries doesn’t exist already although your article suggests that the directory needs to be copied and pasted over writing what’s there. Should the stproxy directory already exist before now?
I created the stproxy directory and copied the jars to the new directory and continued with restarting the STProxyServer.
After the server started I tried to log in to the stwebclient and on entering my password I am faced with another prompt and I cannot log in.
Looking in the systemout.log I see that there are errors referring to LTPA.
[11/26/10 14:46:22:382 GMT] 00000024 ClusterManage I com.ibm.rtc.stproxy.cluster.ClusterManager serverLoggedIn CLFRX0006I: Sametime Proxy server is successfully connected to the Sametime community, server name is CN=ACME Sametime/OU=Servers/O=ACME, server id is 0 0ac176043
[11/26/10 14:46:22:384 GMT] 00000024 ClusterManage I com.ibm.rtc.stproxy.cluster.ClusterManager serverLoggedIn CLFRX0001I: local community is connected
[11/26/10 14:47:18:920 GMT] 00000026 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stwebclient] [/index.jsp]: Initialization successful.
[11/26/10 14:47:19:120 GMT] 00000027 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stwebclient] [/i18nStrings.jsp]: Initialization successful.
[11/26/10 14:47:20:878 GMT] 00000027 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stwebclient] [/popup.jsp]: Initialization successful.
[11/26/10 14:47:21:100 GMT] 00000027 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stbaseapi] [/iframeProxy.jsp]: Initialization successful.
[11/26/10 14:47:21:156 GMT] 00000027 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stwebclient] [ServerConfiguration]: Initialization successful.
[11/26/10 14:47:24:201 GMT] 00000027 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stbaseapi] [Interceptor]: Initialization successful.
[11/26/10 14:47:24:221 GMT] 00000028 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stwebclient] [Interceptor]: Initialization successful.
[11/26/10 14:47:24:530 GMT] 00000026 servlet I com.ibm.ws.webcontainer.servlet.ServletWrapper init SRVE0242I: [SametimeProxy] [/stbaseapi] [/hubClient.jsp]: Initialization successful.
[11/26/10 14:47:30:697 GMT] 00000026 TrustAssociat A SECJ0121I: Trust Association Init class com.ibm.ws.management.system.smgr.JobManagerTAI loaded successfully
[11/26/10 14:47:30:699 GMT] 00000026 TrustAssociat A SECJ0122I: Trust Association Init Interceptor signature: 1.0
[11/26/10 15:00:56:387 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.37860295509169931496.txt com.ibm.websphere.security.PasswordCheckFailedException 190
[11/26/10 15:00:56:397 GMT] 00000027 DMAdapter I com.ibm.ws.ffdc.impl.DMAdapter getAnalysisEngine FFDC1009I: Analysis Engine using data base: /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/properties/logbr/ffdc/adv/ffdcdb.xml
[11/26/10 15:00:56:415 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.3769052188655881354899.txt com.ibm.ws.security.ltpa.LTPAServerObject.authenticate 947
[11/26/10 15:00:56:416 GMT] 00000027 LTPAServerObj E SECJ0369E: Authentication failed when using LTPA. The exception is .
[11/26/10 15:00:56:424 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.4207306109142222307389.txt com.ibm.websphere.security.auth.WSLoginFailedException 186
[11/26/10 15:00:56:430 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.4183717847918779241439.txt com.ibm.ws.security.server.lm.ltpaLoginModule.login 452
[11/26/10 15:00:56:436 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.4324685017721672519370.txt com.ibm.ws.security.server.lm.wsMapDefaultInboundLoginModule.login 667
[11/26/10 15:00:56:445 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.4427406922671250651580.txt com.ibm.ws.security.auth.JaasLoginHelper.jaas_login 602
[11/26/10 15:00:56:452 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.4483069289212183396400.txt com.ibm.ws.security.auth.ContextManagerImpl.login 3703
[11/26/10 15:00:56:600 GMT] 00000027 FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on /opt/IBM/WebSphere/AppServer/profiles/st85proxySTPPNProfile1/logs/ffdc/STProxyServer_540e540e_10.11.26_15.00.56.4564729894721154308504.txt com.ibm.ws.security.web.WebAuthenticator.basicAuthenticate 1745
[11/26/10 15:01:08:743 GMT] 00000027 LTPAServerObj E SECJ0369E: Authentication failed when using LTPA. The exception is .
I also see errors in iNotes.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; InfoPath.2; .NET4.0C; .NET4.0E; AskTB5.6)
Timestamp: Fri, 26 Nov 2010 15:30:09 UTC
Message: Permission denied
Line: 26
Char: 14590
Code: 0
URI: UK.COM
Message: ‘window.parent.initHub’ is null or not an object
Line: 33
Char: 4
Code: 0
URI: http://st85proxy.ad.tpp.uk.com:9080/stbaseapi/iframeProxy.jsp?isConnectClient=false&xDomain=tpp.uk.com
Line: 8
Char: 2222
Code: 0
URI: UK.COM
I extracted the files from my laptop (Windows) and copied them to my Linux server. I have also changed the directory and files permissions using chmod -R 755 just in case it may have been a permissions issue.
I can roll back the STProxyServer.ear to a copy I took prior to these changes and things work fine. Any help is appreciated.
Subject: Can someone please post an update on this??
I have the tech preview. I have inotes 8.5.2. I have ST proxy 8.5.1
AS the previous user, I installed all the stuff per the insturctions. It went fine. But it does not work. I get a windows login type pop up. Do I really have to use ST proxy 8.5 (instead of 8.5.1)?? If so how do I install an 8.5. proxy as the ST system console will nto let me install an 8.5 version. There option for it but since my ST community server is 8.5.1 it doesn’t let me create a deployment (or something).
I opened a PMR but they are clueless and said that the technology preview is just instructions to install a sametime proxy server and it won’t work until proxy server 8.5.2 is available. I think that is incorrect. Can someone who is involved with this “technology preview” please contact me and help me get this working? We are an iNotes-only shop and DYING to get off of stlinks.
thanks
Gabe Zashin
Thomas Jefferson Hospital
Subject: Configuration Issue
The iNotes Sametime Proxy package update is only supported on Sametime Proxy 8.5.
Subject: Any plans to release for 8.5.1?
Thanks Mark, I’ll apply it to an 8.5 server and test again. Any ideas of when this will be supported and which versions of Sametime, Sametime 8.5.3 for example?
Subject: Sorry I mean 8.5.2.
Subject: It is planned to be available with Sametime 8.5.2. </>
Subject: Thanks for the update - will be good for a great many customers
Subject: Still not working in IE8 after reverting to Sametime 8.5
I have reverted to Sametime 8.5 and followed the instructions in your Developerworks article and I still get errors in IE8 when accessing iNotes. I can now though log in to the Proxy web client something I couldn’t do when using ST 8.5.1.
When testing this with Firefox it works, any ideas why it’s not working with IE8??
Timestamp: Fri, 3 Dec 2010 09:59:15 UTC
Line: 26
Char: 14590
Code: 0
URI: UK.COM
Line: 33
Char: 4
Code: 0
Line: 8
Char: 2222
Code: 0
URI: UK.COM
Firefox - looks good and very quick to load
