Author / Reader field refresh problem
Hello fellas,
My database has a default access level of Author. I have created a button that is sent in a note to various people. And what it basically does is create a document ( via Lotusscript back-end objects ) in the database and fill it up with some info.
The problem is, the Authors field in the document only does what it is supposed to when I open the document in the client, save it and close it again. :frowning:
Isn’t there a way to get that field to behave properly from the start?
I appreciate any feedback, thank you!
Subject: Author / Reader field refresh problem
You need to mark the item as Authors, either by getting the item and setting its IsAuthors property to True or by creating the item by using New NotesItem(doc,Name,Value,AUTHORS).
Subject: RE: Author / Reader field refresh problem
Worked perfectly, thanks a lot!!! :slight_smile:
