Archive settings disabled by Admin, need to bypass archive settings to archive in another db
Suddenly, our admin has decided to take over the archive settings and has set a default condition of not modified for 7 days!!
I get about 100 emails everyday, which after processing I would move to specific related fodlers and from this I had a process of archiving it immediately.
Now it has to wait for 7 days!! Which is painful.
Second issue: This Admin has put the new archive db on the server and my other archive is local (which has over 1 gb of archived data). So when I need to search old mails I need to first check old archive, then the new one on the server…too time consuming.
What I am currently doing is that once my work is done I am manually moving the emails form my various folders to my local archive …but I found this time consuming too!
I tried writing an agent which would move to separate database, but the mails go into All documents view and dont go into respective folders.
Can anyone help?
Please?
Thanks,
-=KoolPal=-
Subject: Archive settings disabled by Admin, need to bypass archive settings to archive in another db
There is an "archive profile"in the database which specifies where is the archive db.
Maybe, you can modify those settings.
You can see this profile with NotesPeek.
