Application reference Lotus COM on system without Notes
Hi, AllI have a VBA application (in Excel) that have Lotus Domino Object (domobj.tlb) referenced in project.
I need that appl run also on PC that don’t have Lotus Notes installed.
Appl verify itself, at runtime, if notes is installed and, if not, don’t use the domino object during execution, but the fact that project had in its references domobj generate a runtime error prior that appl run.
I have tried to copy in PC all modules that I know to be interest by domino object: Nlsxbe.dll, Domobj.tlb and Notes32.tlb, and then attempt to registry nlsxbe.dll, but it was failed.
Can anybody help me to :
  1. found all modules that are interest by domino object so that I can successfully register it, to became available to appl, without install Notes; or
  2. suggest me another valid solution for my problem.
Thanks in advance,
Best Regards,
Sauro.
Subject: Application reference Lotus COM on system without Notes
You need to use late binding
See this article for an explanation:
http://www.dicks-clicks.com/excel/olBinding.htm
The prog ID for the NotesSession object is Lotus.NotesSession
