I am creating an email with Body as the Rich Text Item.
I use AppendRTItem to append another rich text item that contains a graphic into the Body field. I also have 4 tables I am adding to the Body with an Call rtBody.AddNewLine(1, True) between each table.
It works fine when the email is sent internally and viewed through a Notes Client. However, when sent to an outside internet address and viewed through an external email client, such as Earthlink, the AddNewLine call is not recognized.
When I remove the AppendRTItem call, the AddNewLine calls are recognized and the email looks correct in the external email client.
Should I append a instead of the AddNewLine?
I am using Call rtBody.Update after the AppendRTItem as well as after each table is being created. Each AddNewLine is set to Call rtBody.AddNewLine(1, True).
Subject: AppendRTItem does not allow AddNewLine to work correctly on web
I looked at the email with the graphic and without a graphic and the only difference is that without the graphic, a is placed between the tables and with the graphic, there is none…
Something in the conversion process to HTML where it sees a graphic and removes breaks?
Subject: SOLUTION: AppendRTItem does not allow AddNewLine to work correctly on web
The only solution I could come up with was to create a document (a lookup document is what I used) that had an empty rich text field on it. The document had been saved.
I then did the old AppendRTItem where I wanted the line break and it seemed to work — it kept the in the email…
Not sure if this is the perfect solution, but it is working for me…
