We installed a new R6 server and already had a R5 server in the same domain. Replication right now is disabled between them. Are there any issues with allowing them to replicate? What about the people who are still using the R5 client?
Subject: I’d recommend reading the coexistence sections of the R6 upgrade redbook
Subject: Any problems replicating between R5 and R6 servers
If they share a NAB, I wouldn’t recommend letting the R6 design replicate to the R5 server.
R5 clients can access an R6 server, but will not be able to use R6 design elements - you can replicate over any custom apps you have on your R5 server and they’ll work (with a few exceptions).
