What a good antivirus and antispam solution to integrate with my Lotus Domino 8.5 ?
Subject: Barracuda or TrendMicro
If your concern is only email between your organization and the outside world (where almost all threats enter the organization), then you really can’t beat this:http://www.barracudanetworks.com/ns/products/spam_overview.php
If you need to also scan internal email, file attachments to Domino applications, and replication events, then you need this:
Subject: these are mail only antivirus tools (?)
Kaspersky has application level (not only email) antivirus, but no update for version Domino 8.x yet.
http://usa.kaspersky.com/products_services/business/components/anti-virus_lotus_notes_domino.php
Subject: SpamSentinel
SpamSentinel is a very good AntiSpam und AntiVirus Solution.
They also offer hosting both services on their side, thats what we use.
regrards
Tibor
Subject: Cisco Ironport ESA
If your concern is only at the edge, I recommend Cisco Ironport’s Email Security Appliance. Best MTA I’ve every worked with!
Subject: Trend micro or Spamsentinel
I have very bad experiences with McAfee Groupshield.
Trend Micro is OK
I prefer Spam Sentinel of Maysoft. Very nice integrated in Domino and also very good support!
Regards,
Peter
Subject: Spam Sentinel
I tried Spam Sentinel and it’s really efficient.
Easy to install
Perfectly integrated with Domino
It blocks all the spam and virus
Also, the Maysoft Support is fantastic.
Regards,
Roberto
