Hello, I am attempting to leverage a new component (MLKit Barcode/QR Scanner) that we imported from the Marketplace. Following the supplied documentation, there are some package dependencies, so I need to add values to the Gradle entries under the Android project settings. Screenshot from the documentation:
After adjusting the build.grade entires to Suffix values, I am having trouble generating a successful android build. I have tried with the (old) versions in the sample, as well as the up to date version of each package. I can tell that it seems to find the packages, because if I put a version/name that simply does not exist then I will see a new "not found" error with the offending package name.
There are several warnings, and the actual build failure appears to be
It seems like there is some sort of conflict being introduced (likely related to existing Android FFIs that are still leveraged in the project).
I am looking for advice around resolving these Android build issues in the use case where we have existing Android FFIs in an older project, but need to import libraries through the Gradle configuration to support a Marketplace component.
Iris: 9.5.11
Android Target Version: 13
Android Studio Version: Hedgehog 2023.1.1
