For the past 2 days the scheduled agents on one of our servers has stopped running, for what seems to be no apparent reason.If I start one manaully it runs as normal but will not write any details to log.nsf.
If we bounce the Domino Server normal service resumes till the next day, agents run and log files are written to!
While no changes have been made either within Notes or our backup process, I have noticed one message within log.nsf which is new compared to usual:
“23/06/2005 02:36:03 AMgr: Unable to open ‘blah\maindb.nsf’. Skipping database: This database is currently being used by someone else. In order to share a Notes database, all users must use a Domino Server instead of a File Server.”
This has happened for the past 2 days right after the Refrsh Agent Cache!
Please help a very confused soul if you can!
Subject: Agents not running as scheduled
Yes. Probably backup software.
The error indicates something other than Domino has the file open – thus Domino tasks cannot open it. When an NSF is opened, it is locked. Only one process at a time can read the NSF.
A second possibility would be that some user/admin has opened the database directly. Are any of your server’s drives shared? Do any admins ever go to the console and open a Notes client? Either of these actions (though occasionally very useful) can be very dangerous to your data.
Hi Ian,
Have you got backup software running? I’ve seen this kind of thing happen where the backup ran on for longer than usual and still had a handle on a user’s mail file when they tried to get in to it in the morning.
Emily.
Subject: RE: Agents not running as scheduled
Hi Emily,Thanks for the response, I’ve checked with our desk top guys here and ARC Serve completed around 11pm both nights, which is a good few hours before the log entry, to their knowledge nothing has changed from there side of things.
We are going to try a simple reboot of the server itself incase it closes any un-detected sessions for our DB.
Hopefully I’ll be on here tomorrow with some good news! :o)
thanks again
“Drop All” when issued on the server console will kill all user sessions.
