I used the admin agent (version 4.0.2.6) on all my users’ mail files to correct entries that are off by an hour because of the DST changes.
Some calendars were corrected and some were not. The ones that were not still show the entries an hour later in the calendar view. Then when I open the entry, it shows the correct time.
A new agent was released so I ran the newer agent (4.0.2.7) on the calendars that were not corrected. There was no change. I used the View and Select agents (4.0.2.7) on a few calendars but that did not correct the entries either. I cannot find anything consistent about the calendars that are not getting corrected. Some of the calendar entries were entered way back in September, others in January or February.
All of the workstations received the DST patch via our Windows WSUS server in November. I ran the TZEdit tool on our Windows 2000\Domino server in January, corrected the Forms6.nsf file and removed the DSTLaw variable in the INI. All of our workstations have Notes 6.5.5.
Has anyone else run into this? Any ideas?
Thanks,
Greg
