Dear ALL,
I need some urgent help. I have created one table by the agent (writing HTML ) . THis table has some check box . Now table is absolutly fine and all check box are coming .Now My problem is that I have to select one check box and on selection all other check box should get selected.
I am calling that function from the agent but it is prompting that object is required. I have defined the function in the js header.
Please advice
Mike
