I have a frameset with 2 frames, frame a and frame b. In frame a, I have a form with a submit button. When the button is presses a webquerysave runs an agent (ToolsRunMacro).
The agent uses a print command in Lotus Script to print out html. Everything works, but i would like the output of the print command to be displayed in frame b.
Is there something I have to add to the sript to specify the target frame ?
Thanks in advance for you help
Neil
