I am a very novice designer compared to what I see on this site. I have an agent designed to look at a documents creation date and status field (either “pending” or “delivered”) and if the creation date is more than 5 days old and the status field is still “pending” then it should e-mail the manager. It works when run manually but when I set it to run at 8:15am for example, no e-mails ever come through. Any ideas?
Thanks for your help.
Subject: Agent not running when scheduled
What does the logs say. I would hazard a guess that it says the agent is meant to be run on your mail server not the server in question or you don’t have permission to run the agent if it is signed with your ID.
You may need your adminstrator to sign with the Server ID
There could be plenty of causes. Is the agent showing any signs of running (from the server / agent logs) or did it never fire in to life.
Julie wrote a large Agent FAQ for R4/5 which is still applicable in R6, worth systematically working through it.
http://www-10.lotus.com/ldd/46dom.nsf/7e6c7e584a76331b85256a46006f083e/574c99ccb345839185256976004e811e?OpenDocument
HTH - Rufus.
Any UI objects declared in it?
