Agent does not exist problem..Please help!
Hello,
I dont know if I’m doing anything wrong. Yesterday I REMmed one of command’s which runs and agent . Agent property is “Run from Agent list” , so its a hidden agent . While calling the agent I’ve given a correct name as “(Agent Name)” .
but today when I’m trying to run , I’m getting an error “Agent does not exist”. I tried changing the agent property to Actions Menu Selection , but still I get the same error , eventhough I can see the agent in Actions Menu list.
Can anyone tell me why is it happening .
Thanks in advance
Tom
Subject: Agent does not exist problem…Please help!!!
Hi Tom.
It could be a few different things.
  1. Make sure the agent isn’t a private agent. The server won’t be able to see a private agent.
  2. Check for any aliases in the name of the agent. If the agent name is “Agent Name|A_Name”, then you couldn’t access it by “(Agent Name)”. To access an agent with an alias, you should explicitly name it with the parenthesis - “(Agent Name)|A_Name”
