I was interested in using the Work Order Management (Offline Enable) component to test it. I downloaded the component, imported it into Iris, and when running it in Live Preview mode, the program stops due to a SDK error stating:
"voltmx.sdk.OfflineObjects.setToken is not a function"
- Exact and full Volt Iris version: Version 9 Service Pack 5 Fix Pack 50 (2025.02) / Volt Flare Framework / Exact Version: 9.5.50
- OS on which Foundry is installed: Linux
- Are you using Foundry Cloud or Foundry On Prem?: Foundry Cloud
- Sample application to reproduce at our end:
When downloading the Work Order Management (Offline Enable) component/asset, you receive a .zip file, which is imported directly into Volt Iris. It automatically imports the application into Foundry and notifies me that the component was built in a previous version. I proceed, and once everything is imported, I run a Live Preview exclusively for mobile devices (Android/iOS Phone).
The system prompts me to publish the Foundry application, so I publish it and launch the app. However, upon startup, the application freezes, and the debug console should display an error stating that the SetToken method from the SDK is not a function.
