Advice needed: start right now with Connections 6.5 CR1 or wait for v7?
I am building a connections environnement for a customer.
Should I halt until v7 is out and start directly with it or start with v6.5CR1 and make an update later ?
I do not understand your question. Could you be more specific regarding the term "start"?
Starting to
- setup the necessary infrastructure
- learn how to install Connections
- setup a new Enterprise Social Network for the users
Setup a pilot environnement for a small group of users (50/100) inside our firm.
So setup necessary infrastruture (already started this point) + Install connections (DOmino/DB2/Wbepshere/Connections soft/Kudos)
Start now with v6.5 CR1 for a small group.
Register for v7 preview and get used to look and feel of new features (new community wizard).
Whether you should wait with the rollout / onboarding of the majority of the users or not might depend on your users ability to cope with changing UI / UX - ability to cope with evergreen approach.
My 2 cents.
As Connections v7 is an in-place upgrade for Connections 6.5 CR1, it doesn't hurt to install 6.5 CR1 already. Then when v7 is out, you can do the upgrade.
It also depends though on what else your company is using. One of the highlights of Connections 7 will be the integration with Microsoft's Office 365. If your company is a big user of M365 then it's probably worth waiting with going live till Connections 7, as it might improve the adoption of Connections by a fair amount if users can immediately see the benefits of the integration. If your company doesn't use M365 then the difference between 6.5 CR1 and 7 aren't that big
