In a test environment, we have installed a 8.0.1 64bit Domino on Windows 2003 Server.
Some of our LotusScript Agents are running on the server and utilize some more or less complex Notes and Windows API calls- which are causing crashes of our test servers now.
Documentation and example resources on this topic are very rare at the moment. I know there are issues with API calls and data types unter 64bit, but is there any clear guideline how to “migrate” the old API calls to a 64bit version of them?
Example: Even this simple API-Call to the windows subsystem brings the server down, but it is running perfectly on a 32bit Domino Server (even under 64bit Windows) and Domino Designer:
Const MAX_PATH = 260
Declare Function GetTempPath Lib “kernel32” Alias “GetTempPathA” (Byval nBufferLength As Long, Byval lpBuffer As String) As Long
Function GetWindowsTempDir() As String
If IsDefined("WINDOWS") Then
Dim hlp As String*MAX_PATH
Dim t As Long
t = GetTempPath(MAX_PATH, hlp)
If t = 0 Then
GetWindowsTempDir = Curdir("C") 'use current directory by default
Else
GetWindowsTempDir = Mid$(hlp, 1, t)
Else
'currently only for Linux (32bit)
GetWindowsTempDir = "\tmp"
End Function
I guess that the problem here is the “long” parameter in the declaration, since library and method name should be the same in 32 and 64bit Windows.
But: How would this look like “translated” for 64bit Windows?
And - even more interesting - how to develop/debug an agent in the designer when the designer is only running in the 32bit context of windows? Do I have to use the “try and error” method by running an agent on the server, e.g. as a scheduled agent?
Help would really be appreciated.
